Change Log & Release Notes
Please note that the Trusted Firmware-A Tests version follows the Trusted Firmware-A version for simplicity. At any point in time, TF-A Tests version x.y aims at testing TF-A version x.y. Different versions of TF-A and TF-A Tests are not guaranteed to be compatible. This also means that a version upgrade on the TF-A-Tests side might not necessarily introduce any new feature.
Version 2.13
New features
More features and tests are introduced in this release to enhance validation and support in the following areas:
  • Realm Management Extension
  • FF-A and SPM Testing
  • Fuzzing Framework
  • System Functionality Tests (e.g., PointerAuth, RAS registers, SMCCC feature availability, FPMR access)
  • Firmware Handoff
  • Platform Enhancements
  • Added and updated tests for FEAT_MPAM on Realms.
  • Added AUX RTT support for planes.
  • Added MbedTLS as a submodule.
  • Added PCIe helpers.
  • Added support for planes shared buffer.
  • Added support for RSI Planes ABI.
  • Added support for s2poe/pie for planes.
  • Added test for multi REC planes.
  • Added test for RSI_PLANE_REG_READ/WRITE command.
  • Added test for validating RTT calls.
  • Added test case to enter all planes.
  • Added tests for realm attestation.
  • Allocated memory for multiple planes.
  • Called RMI_PDEV ABIs from host realm management.
  • Enhanced Realm memory exception tests for planes.
  • Extended RIPAS tests for planes.
  • Fixed rmi_realm_params structure not being zeroed upon realm creation.
  • Fixed bug in RMI_RTT_SET_S2AP command helper.
  • Fixed multi REC PMU tests.
  • Fixed PMU save/restore registers.
  • Fixed position of RTT_S2AP_INDIRECT bit in RmiFeatureRegister0.
  • Fixed Realm PMU tests.
  • Fixed Realm tests marking all memory as RAM.
  • Fixed the LPA2 flag setting for BRBE test.
  • Handled permission fault for planes.
  • Made PCIe tests default for testing.
  • Undelegated PDEV granules upon DA ABI failure so later tests do not fail.
  • Validated NS EL1/EL2 context is preserved by RMM.
TFTF
  • SPM/FF-A Testing:
    • Added a second instance of the Cactus S-EL1 partition to validate HOB generation.
    • Added support for PPI timer interrupts.
    • Added v1.2 fields to RXTX header.
    • Fixed indirect messaging tests by adding ME handling.
    • Introduced an enum type for FF-A errors.
    • Refilled TX buffer after undelegation.
    • Skipped CPU cycle allocation for SP vCPU to reach message loop.
    • Skipped enabling/disabling SRI physical interrupts in TFTF.
    • Specify the secure partition package for an SP
  • New Tests
    • Fuzzing Enhancements
      • Added fuzzing for vendor EL3 SMCCC calls.
      • Enabled capability for randomized fuzzing inputs.
      • Fixed single-feature testing behaviour.
      • Introduced support for all SDEI calls, and the FF-A interface.
    • Functionality Tests
      • Added RAS system registers access test.
      • Added test for SMCCC_ARCH_WORKAROUND_4.
      • Added test for ARMv8.3 PointerAuth instructions.
      • Added test for FPMR register access.
      • Added tests for SMCCC_ARCH_FEATURE_AVAILABILITY.
      • Added two new features and fixed TRNDR handling in availability tests
      • Check SCTLR2, THE and D128 sysregs read/writes work as expected.
      • Denied prohibited ABIs during CPU_OFF PSCI message handling.
      • Evaluated EL3–RMM IDE KM interface in TRP.
      • Validated psci_is_last_cpu_to_idle_at_pwrlvl.
      • Verified save/restore logic for BRBCR_EL1.
    • Firmware Handoff
      • Added AArch32 handoff tests.
      • Imported Measured Boot drivers from TF-A to support event log testing.
      • Added tests for validating an event log received from a Transfer List.
  • Platforms:
    • Versal NET
      • Provided fix to prevent continuous interrupts by properly cleaning up TTC timer in cancel routine.
    • Versal
      • Added platform specific function to return custom entry address.
      • Updated Versal-2 test skip list.
      • Updated Versal-2 TFTF and UART base address.
    • Neoverse-RD
      • Added TFTF support for RD-V3 platform.
      • Deprecated and remove NRD1, RD-N1-Edge, RD-V1, SGI-575 platform variants.
  • Miscellaneous
    • Added bdf macro.
    • Added xpaci instruction to exception report.
    • Added build flag to control support for CPU_OFF PSCI message.
    • Added Cortex-X925 and updated Cortex-X4 to Errata ABI.
    • Added HOB definitions to TFTF.
    • Added MbedTLS support and updated version to v3.6.3.
    • Added new interface to get an invalid entrypoint address.
    • Added register definitions needed for SMCCC_ARCH_FEATURE_AVAILABILITY
    • Added split workaround check in Errata ABI test.
    • Added support for SMC calls with no ret vals in x8.
    • Updated ARM GCC toolchain requirements to 14.2.Rel1.
    • Updated Cortex-A710 errata list.
Cactus (Secure-EL1 FF-A test partition)
  • Added boot-time prints for Cactus-StMM HOB list.
  • Added support for receiving PSCI messages through direct request framework message.
  • Added mapping for boot information regions.
  • Moved StMM to Cactus tertiary.
Issues resolved since last release
  • Applied fix to synchronize SME context before it is used.
  • Fixed reporting of BRBE support with later revisions.
  • Fixed compile error in test_irq_spurious_gicv2.c.
Version 2.12
New features
  • More tests are made available in this release to help validate the functionalities in the following areas:
    • FF-A
    • EL3 Runtime
    • New Platform ports
TFTF
  • SPM/FF-A Testing:
    • Added tests to attest SPMC handles GPF in memory sharing ABIs:
      • FFA_MEM_RETRIEVE_REQ
      • FFA_MEM_FRAG_RX/TX
      • FFA_MEM_RELINQUISH
    • Added tests using the SMC64 ABI version for the FF-A memory management interfaces.
    • Tests to attest the SPMC is doing the necessary context management of SME registers.
    • Check that SRI delay flag use from normal world results in an error.
    • FF-A Setup and discovery interfaces:
      • FFA_VERSION called restricted to be used until first FF-A call, from a given endpoint is handled.
      • FFA_FEATURES tests changed to cater for feature return based on EL of the FF-A endpoint, and the security state it relates to.
      • FFA_PARTITION_INFO_GET changed to report support of indirect messaging.
    • New tests
      • Added AMU counter restriction (RAZ) test.
      • Added test to validate EL1 and EL2 registers during context switch.
      • Added PCIe DOE library and tests.
      • Added tests for newly supported features FEAT_FGT2, LS64_ACCDATA, FEAT_Debugv8p9.
      • Added test for 64-byte load/store instructions introduced by LS64.
      • Added asymmetric feature testing for FEAT_SPE, FEAT_TRBE, and FEAT_TCR2.
      • Added a new test suite supported by EL3 SPMC.
      • Added SDEI tests for attempting to bind too many events.
      • Added test suite to exercise SIMD context management with Cactus SP (supported by EL3 SPMC).
  • Platforms
    • Corstone-1000:
      • Updated test skip list.
    • FVP:
      • Added PCIe support.
    • Neoverse-RD:
      • Defined naming convention for CSS macros.
      • Introduced flash and ROS macros.
      • Introduced timer and watchdog macros.
      • Refactored header files for first gen platforms.
      • refactored header files for second gen platforms.
      • Removed deprecated header files.
    • Versal-2:
      • Added support for AMD Versal Gen 2 platform.
      • Added AMD Versal Gen 2 documentation.
  • Miscellaneous:
    • Added skeleton for asymmetric feature testing capability.
    • Added asymmetric tests to skip when features are not present on a core.
    • Added test to ensure arch timer in NWd is honored across world switch.
    • Added test to confirm errata 2938996/2726228 workaround by checking trbe_el1 access.
    • Fixed GICD_ITARGETSR assertion to relax check on unicore systems.
    • Fixed expect to print file and line number on failure for easier debugging.
    • Fixed TRBE extension test to skip on Cortex-A520 and Cortex-X4 due to errata.
    • Refactored to register undef_injection_handler only during register accesses for better control over exceptions.
    • Fixed firmware handoff register convention value to match updated spec.
    • Updated toolchain requirements.
  • Set number of num_bps and num_wps.
  • Updated rsi_ipa_state_get() function.
  • Increased maximum number of RECs.
  • Use random start REC.
  • Added specific tests for FEAT_LPA2 on RMI tests.
  • Added support for FEAT_LPA2 to the Realm Extension tests.
  • Added test for rtt_fold unassigned.
  • Added test for rtt_fold assigned.
  • Unified SIMD test cases.
  • Fixed pauth exception test.
  • Fix(realm): cater for removal of SH from rtte.
  • Fixed RMI and RSI definitions to match RMM Specification 1.0-rel0-rc1.
  • Fixed RMI commands arguments descriptions.
  • Fixed calculation of Realm’s REC index.
  • Fixed host_realm_init_ipa_state()’s retry path.
  • Fixed realm initialisation code.
  • Separated pool creation from Realm creation helpers.
  • Fixed tests passing with TRP but not with RMM.
  • Added support for Cactus SP to boot on EL3 SPMC.
  • Added fix to skip computing linear core id.
  • Fixed cactus_mm verbosity on some tests.
  • Added “build” directory dependency to ensure correct ordering on slow systems.
  • Fixed race condition in tests_list generation by using grouped target.
  • Fixed virtual timer enablement by moving it to command handler.
  • Fixed test case test_smccc_callee_preserved.
  • Updated definitions for sysregs on older toolchains.
  • Fixed undef_injection_handler to clarify it catches both undef injections
and EL2 register traps.
Version 2.11
New features
    • FF-A
    • EL3 Runtime
    • Negative Boot-Test Framework
TFTF
  • SPM/FF-A testing:
    • Added test to ensure MTE registers are restored upon context switch.
    • Indirect message: Added framework code and tests (messaging VMs to SPs; aborted FFA_MSG_SEND2 call from both SPs and TFTF).
    • Added framework notification helpers.
    • Added test to check that NWd can’t lend/donate realm memory.
    • Added test that accesses all constituents descriptors of memory share.
    • Test to validate of GPC with memory sharing.
    • Test FFA_FEATURES to obtain interrupt IDs for: Notification Pending Interrupt, Schedule Receiver Interrupt and Managed Exit.
    • Increase test coverage for FFA_RXTX_MAP/FFA_RXTX_UNMAP.
    • Test to check that FFA_FEATURES returns max RX/TX buffer size.
    • Added helper functions for getting string representations of function. identifiers and error codes.
    • Added impdef field to ffa_memory_access structures.
    • Updated FF-A version for sp_test_ffa.c and memory sharing tests to v1.2.
    • Refactored helpers that use bitfields for memory access bitmaps.
    • Refactored ffa_memory_access constructors.
    • Renamed SPM cpu_features to SIMD.
    • In FFA_MSG_SEND_DIRECT_REQ/FFA_MSG_DRIECT_REQ2 calls return FFA_ERROR(FFA_BUSY), with establishing cycling dependencies.
    • Added validation to detect if FFA_SECONDARY_EP_REGISTER is supported.
    • Tests for Hypervisor retrieve request: contents checks, fragmented request, verify receivers.
    • Test to verify FFA_MEM_LEND/FFA_MEM_DONATE in a RME enabled platform.
    • Fixed a few arguments used in the hypervisor retrieve request tests.
    • Fixed notifications test to clean-up after itself (destroy bitmap for receiver VM in SPMC). allocated for the VM in the SPMC.
    • Exercise DMA isolation for secure access to Non-Secure memory.
  • New tests:
    • Introduced UNDEF injection test.
    • Added test for SMC vendor-specific service.
    • Added test for PMF version check via SMC.
    • Refactored to group all SMC tests.
    • Tested trusted key certificate corruption.
  • Platforms:
    • SGI:
      • Replaced references to “SGI”/”sgi” for neoverse_rd.
      • Renamed “CSS_SGI” macro prefixes to “NRD”.
      • Moved APIs and types to “nrd” prefix.
      • Replaced build-option prefix to “NRD”.
      • Regrouped “sgi” and “rdinfra” to “neoverse_rd”.
      • Increased the number of XLAT tables.
    • Versal:
      • Skip hanging TSP test cases.
    • Versal NET:
      • Removed TSP tests from skip list.
      • Temporarily disabled the hanging TSP test cases.
      • Corrected core position function.
    • TC:
      • Updated UART base for TFTF.
      • Made TC0 TFTF code generic to TC.
    • Xilinx:
      • Moved TTC_CLK_SEL_OFFSET to platform_def.h.
      • Added Xilinx platforms to docs.
    • ZynqMP:
      • Introduced platform support.
      • Added documentation.
  • Miscellaneous:
    • Refactored DebugFS and PMF as vendor-specific el3 services.
    • Added Cortex-A520, Cortex-X3 and Cortex-X4 cpu structures for errata ABI.
    • Added SMCCCv1.3 SVE hint bit support in TFTF framework.
    • Added TSP testing, multi-CPU capability, new test function and enhanced. performance for SMC fuzzing.
    • Added MPAM system registers access test.
    • Updated register signature for Firmware Handoff.
    • Updated toolchain requirements in docs.
    • Updated links to TF-A Tests issues tracker.
    • Refactored SDEI test to align with new SPSR config.
    • Removed some tests from extensive test list.
    • Moved test suite “SP exceptions” from ‘tests-spm.xml’ into. ‘tests-memory-access.xml’.
    • Disabled RWX segment warnings for the EL3 payload.
Realm Management Extension (RME)
  • Added test for enabling pmu with multiple rec.
  • Added testcase for access outside realm IPA space.
  • Added ability to overwrite s2sz for creating realm.
  • Added tests for PAS transitions.
  • Added test for FEAT_DIT.
  • Test realm PAuth state is preserved.
  • Added testcase for Synchronous external aborts.
  • Added testcase for REC exit due to Data/Instr abort.
  • Removed unwanted arg from realm API.
  • Fixed realm_printf string.
  • New API to create and activate realm.
  • Testcase for multiple realms.
  • Added support for multiple realm.
  • Removed pack_realm build target.
  • Test to use SVE hint bit feature.
  • Removed unwanted host_rmi_rtt_init_ripas.
  • Testcase for multiple REC validations.
  • Changed Realm create and execute API.
  • Testcase for RMI_RTT_SET_RIPAS reject.
  • Added testcase for multiple REC on multiple CPUs.
  • Added support for RSI_IPA_STATE_GET/SET.
  • Added realm_print_exception for Realm payload.
  • Force max IPA size on Realms to 48 bits.
  • Fixed Realm destroy API.
  • Fixed Realm vbar_el1 load address.
  • Fixed return value of host_enter_realm_execute call.
  • Fixed host_call structure should be per rec.
  • Fixed issue in RTT teardown.
  • Fixed initialization of RIPAS is incorrectly done on TFTF.
  • Fixed host_realm_init_ipa_state() is called with wrong args.
  • Added SMMU test engine header file.
  • Added MEMCPY and RAND48 to the SMMU test engine.
  • Added ability to send indirect messages.
  • Added support for fake RAS handler command.
  • Replaced tftf_smc with ffa_service_call.
  • Refactored cactus to handle expect exception.
  • Refactored first cactus SP to use FFA_CONSOLE_LOG instead of UART.
  • Replaced platform_get_core_pos with macro that retrieves vCPU index.
  • Check for null before calling I/O policy callback.
  • Mapped NS buffer only if needed for SMMU tests.
  • Fixed comments referencing “SGI platform”.
  • Specified properties to corresponding memory region nodes.
  • Increased TESTCASE_OUTPUT_MAX_SIZE for printf.
  • Save and restore SMCR_EL2 upon CPU suspend and resume.
Version 2.10
New features
    • FF-A
    • EL3 Runtime
TFTF
  • FF-A testing:
    • Fixing FF-A version tests and expected error codes.
    • Remove SPM tests from AArch32 builds.
    • Support extended set of registers with FF-A calls.
    • Fix use of instruction permissions in FF-A memory sharing tests.
    • Extend memory sharing tests that use the clear memory flags.
    • Test that memory from Root World/Realm can’t be shared.
    • Test the compliance to SMCCC at the non-secure physical instance.
    • Exercise secure eSPI interrupt handling.
  • New tests:
    • Added test for Errata management firmware interface.
    • Added basic firmware handoff tests.
    • Test to verify SErrors synchronized at EL3 boundry.
    • Introduced RAS KFH support test.
    • Modified FEAT_FGT test to check for init values.
    • Updated test_psci_stat.c to support more power states.
  • Platforms:
    • TC:
    • Versal:
      • Added platform support and platform specific cases.
      • Added Versal documentation.
    • Versal NET:
      • Added Versal NET documentation.
    • Xilinx:
      • Reorganized timer code into common path.
  • Miscellaneous:
    • Added helper routines to read, write and compare SVE and FPU registers.
    • New CPU feature detection helpers.
    • Introduced clang toolchain support and added python generate_test_list script.
    • Docs: Updated toolchain requirements and added maintainers for AMD-Xilinx.
    • Tidy setup and discovery logs.
    • Added note on building TFA-Tests using clang docs.
    • Added SME helper routines and added Streaming SVE support.
    • Introduced SError exception handler.
    • Updated toolchain requirements documentation.
    • Check for support for ESPI before testing it.
  • Added SVE Realm tests and tests for EAC1.
  • Test to intermittently switch to Realm while doing NS SVE and Streaming SVE ops.
  • Added tests to check NS SME ID registers and configurations.
  • Added test to check if RMM doesn’t leak Realm contents in SVE registers.
  • Test to check if non SVE Realm gets undefined abort.
  • Test to check various SIMD state preserved across NS/RL switch.
  • Added test to check swtich SME registers to SIMD state.
  • Testcase for CPU_ON denied.
  • Test for multiple REC single CPU.
  • Test for PAuth in Realm.
  • Enhanced FPU state verification test.
  • Modified API of RMI_RTT_*_RIPAS, changed handling.
  • Removed RIPAS_UNDEFINED and modified RIPAS/HIPAS definitions for EAC2.
  • Removed RMI_VALID_NS status and RMI_ERROR_IN_USE error code RMI_RTT_UNMAP_UNPROTECTED and update API of data/rtt functions.
  • Updated RSI_VERSION, RMI_VERSION and modified rmi_realm_params structure.
  • Added support for PMU as per RMM Specification 1.0-eac2.
  • Added PSCI API to Realms and API for REC force exit.
  • Added support for multiple REC and CPU and data buffer to pass arg to REC.
  • Set size of RsiHostCall.gprs[] to 31.
  • Passing RD pointer in arg0 register X1.
  • Added host call to flush Realm prints.
  • Aligned Realm stack.
  • Introduced new build flag for RME stack and appended realm.bin at end of tftf.bin.
Cactus (Secure-EL1 test partition)
  • Test discovery of EL3 SPMD managed SPs.
  • Configure partitions load-address from SP layout file.
  • Use the non-secure memory attribute in descriptor obtain from FFA_MEM_RETRIEVE_RESP.
  • SPs configured with a unique boot-order field in their respective manifests.
  • Test to the FFA_PARTITION_INFO_GET_REGS interface.
  • Defined memory security state attribute for memory transaction desciptor.
  • Fixed incremental build issue with Realm payload and build dependency in test-realms-payload.
  • SME: use of rdsvl instead of rdvl, enable SME/SME2 during arch init, align test vector arrays to 16 bytes.
  • SVE: representing Z0-Z31 as array of bytes and moved operation to a lib routine.
  • Fixed issue in processing dynamic relocations for AArch64.
  • Reclaim and check for shared memory now supported.
  • FPU replaced read with write of random value to fpsr/fpcr.
  • Disabled RMI tests when building for AArch32 architecture.
  • Fixed command id passed to Realm to compare FPU registers.
  • Fixed broken links in docs landing page and made generate_test_list backward compatible.
  • XLAT: added support for 52 bit PA size with 4KB granularity.
  • Fixed stress test for XLAT v2.
  • RAS: Moved wait logic from assembly to C and renamed SDEI related functions/events.
Version 2.9
New features
    • FF-A Features
    • New Architecture Specific features related to v8.8
    • New platform ports
TFTF
  • FF-A testing:
    • Reordered logs in the memory sharing tests.
    • Memory share bumped to v1.1 EAC0.
    • Updated tests for FFA_FEATURES(FFA_MEM_RETRIEVE_REQ).
    • Fixed issues with RXTX buffer unmapping and dependencies on tests.
    • Added check for execution state property of partitions.
  • New tests:
    • Tests for Errata management firmware interface.
    • Ensure FPU state registers context is preserved in RL/SE/NS.
    • Modified FEAT_HCX test to also check for HCRX_EL2 init value.
    • Added basic SME2 tests.
    • PSCI tests for OS-initiated mode.
    • Added “nop” test to be used in conjunction with TFX.
    • Introduced capability to generate Sync External Aborts (EA) in TFTF.
    • New test to generate an SError.
    • Tests to check whether the PMU is functional and if the state is preserved when switching worlds. PMEVTYPER.evtCount width extended.
    • Added support for more SPE versions.
  • Platforms:
    • RD-N2-Cfg3:
      • Added TFTF support.
  • Miscellaneous:
    • SIMD/FPU save/restore routine moved to common lib.
    • Update SME/Mortlach tests.
    • Unified Firmware First handling of lower EL EA.
    • Moved trusted wdog API to spm_common.
    • Added the ability to skip tests for AArch32.
    • Added config file to allow doc defaults be changed.
    • Modified tests for FEAT_RNG_TRAP.
    • Moved ‘Stress test timer framework’ to a new test suite ‘tests-timer-stress’.
    • Support for new binutils versions.
    • Removed deprecated SPM libs and test code.
  • Added helper macro for RME tests.
  • Test Secure interrupt can preempt Realm EL1.
  • Added PMU Realm tests.
  • Added BP_OPTION to REALM_CFLAGS to allow build realm payload with BTI/Pauth support.
  • Fixed build issues introduced by the TFTF Realm extension enhancement tests.
  • Test case return codes updated according to RMM Bet0 specification.
  • Fixed build problem related to rmi_rec_enter verbose log.
  • Added randomization of SMC RMI commands parameters and checking of X4-X7 return values as per SMCCC v1.2.
  • Use of FFA_CONSOLE_LOG for debug logs.
  • Test for consecutive same memory donation to other partitions.
  • Now validating NWd can’t share forbidden addresses.
  • Support for registering irq handlers.
  • Fixed attributes for NS memory region.
  • Removal of memory regions not page-aligned.
  • Added check for core linear id matching id passed by SPMC.
  • Build issue for older toolchains and other failures resolved.
  • Dropped invalid access test from CI.
  • Now checking that the PMU is supported before using any of it.
  • Use of write instead of read to generate an SError to avoid sync exceptions instead.
  • Fixed broken link to TRNG_FW documentation.
  • INIT_TFTF_MAILBOX() is called first for the invalid access test.
Version 2.8
New features
    • FF-A Features
TFTF
  • FF-A testing:
    • UUID included in partition information descriptors.
    • Checks for size of partition information descriptors.
    • Renamed FFA_MSG_RUN ABI function to FFA_RUN and allowed it to return from Waiting state.
    • Made ffa_tests available for Ivy.
    • Updated verbose message log structure.
    • Prevented generate_json.sh from being called more than once by requiring a list of partitions to be supplied.
    • Added a temporary workaround for unexpected affinity info state to prevent a system panic.
    • Added test to exercise FFA_CONSOLE_LOG ABI.
    • FF-A v1.1 Secure interrupts
      • Added managed exit to first and second SP in call chain.
      • Added test to exercise managed exit by two SPs in a call chain.
      • Added tests to exercise NS interrupt being queued and signaled to SP.
  • New tests:
    • Tests for SVE operations in Normal World and discover SVE vector length.
    • Added cleanup TRNG service tests.
    • Added test for SMCCC_ARCH_WORKAROUND_3.
    • Updated PAuth helpers to support QARMA3 algorithm.
    • Added tests for RNG_TRAP.
  • Platforms:
    • SGI:
      • Introduced platform variant build option.
      • Re-organized header files.
      • Migrated to secure uart port for routing tftf logs.
    • N1SDP:
      • Added TFTF support for N1SDP.
    • RD-N2:
      • Added TFTF support for RD-N2.
    • RD-N2-Cfg1:
      • Added TFTF support for RD-N2-Cfg1.
    • RD-V1:
      • Added TFTF support for RD-V1.
  • Miscellaneous:
    • Added a missing ISB instruction in SME test.
    • Refactor to make some helper functions re-usable.
    • Updated build command to clean EL3 payload image.
    • Move renaming of the primary dts file for ivy partitions.
    • Added check that verifies if a platform supports el3_payload before building it.
    • Updated memory share test to meet Hafnium specification.
  • Added Realm payload management capabilities to TFTF to act as a NS Host.
  • Added test to verify that RMM and SPM can co-exist and work properly.
  • Added function to reset delegated buffers to non-delegated state.
  • Re-used existing wait_for_non_lead_cpus() function helper.
  • Refactored RMI FID macros to simplify usage.
  • Added userguide for realm payload testing.
  • Corrected some tests message types from ERROR to VERBOSE.
  • Increased the cactus number of xlat to allow the use of 48b PA size for memory sharing between SPs.
  • Introduced a new direct request message command to resume after managed exit.
  • Skip enabling virtual maintenance interrupts explicitly.
  • Allowed sender to resume interrupted target vCPU.
  • Added support for handling managed exit through vIRQ.
  • Added support for discovering interrupt IDs of managed exit signals.
  • Specified action in response to NS interrupt in manifest.
Ivy (Secure-EL0 test partition)
  • Allowed testing using VHE.
  • Allowed Ivy partitions to use ffa_helpers functions.
  • Requirement of common name for Ivy partitions for consistency.
  • Fixed SME header guard name.
  • Fixed response for incorrect direct message request for FF-A.
Version 2.7
New features
    • FF-A Features
    • New Architecture Specific features related to v8.7
    • New platform port
TFTF
  • FF-A testing:
    • FF-A partition information structure is updated to include UUIDs.
    • Memory Management helper functions are refactored to fetch the details of smc call failures in tftf and cactus.
    • Added test to validate memory sharing operations from SP to NS-endpoint are denied by SPMC.
    • Added test to ensure an endpoint that sets its version to v1.0 receives v1.0 partition information descriptors as defined in v1.0 FF-A specification.
    • Added test to validate that memory is cleared on memory sharing operations between normal world and secure world.
      • Added support to enhance the secure interrupt handling test.
      • Support for registering and unregistering custom handler that is invoked by SP at the tail end of the virtual interrupt processing.
      • Added support for querying the ID of the last serviced virtual interrupt.
  • New tests:
    • Added test to validate that realm region access is being prevented from normal world.
    • Added test to validate that secure region access is being prevented from normal world.
    • Added test to validate that secure region access is being prevented from realm world.
    • Added test to validate that root region access is being prevented from realm world.
    • Added a test for v8.7 Advanced floating-point behavior (FEAT_AFP).
    • Added a SPE test that reads static profiling system registers of available SPE version i.e. FEAT_SPE/FEAT_SPEv1p1/FEAT_SPEv1p2.
    • Added a test to validate functionality of WFET and WFIT instructions introduced by v8.7 FEAT_WFxT.
    • Added basic SME tests to ensure feature enablement by EL3 is proper for its usage at lower non-secure ELs.
    • Added test to check Data Independent timing (DIT) field of PSTATE is retained on exception.
    • Added test to ensure that EL3 has properly enabled access to FEAT_BRBE from non-secure ELs.
  • Platforms:
    • Add initial platform support for corstone1000.
    • TC:
      • Support for notification in tertiary SP manifest.
    • FVP:
      • Support to provide test memory addresses to validate the invalid memory access test from tftf(ns-el2).
  • Miscellaneous:
    • Added support to configure the physical/virtual address space for FVP.
    • Added common header file for defining macros with size to support all the platforms.
    • Introduced handler for synchronous exceptions (AArch64).
    • Added macros to extract the ISS portion of an ELx ESR exception syndrome register.
    • Support to dynamically map/unmap test region to validate invalid memory access tests.
    • Added support to receive boot information through secure partitions, according to the FF-A v1.1 EAC0 specification.
    • Added an helper API function from SPM test suite to initialize FFA-mailbox and enable FF-A based message with SP.
    • Updated the build string to display the rc-tagged version.
  • Added test for nonsecure memory sharing between Secure Partitions(SPs).
  • Added test to validate that a realm region cannot be accessed from secure world.
  • Added test to permit checking a root region cannot be accessed from secure world.
  • Extended the test command CACTUS_MEM_SEND_CMD to add support for memory sharing flags.
  • Added support to save the state of general purpose registers x0-x4 at the entry to cold boot and restore them before jumping to entrypoint of cactus.
  • Fixed a bug to align RMI FIDs with SMCCC.
  • Fixed encoding of vCPU and receiver IDs in the FFA_NOTIFICATION_GET interface to comply with the FF-A v1.1 beta0 specification.
  • Fixed memory retrieve request attributes by enforcing them to be inner shareable rather than outer.
  • Fixed static memory mapping of EL3 in EL2.
  • Fixed a spurious error log message with memory share test.
  • Aligning RMI FIDs with SMCCC.
  • Fixed PSCI system suspend test suite execution in a four world system.
  • Configured the build system to use DWARF 4 standard for debug builds with ArmDS.
  • Introduced macro IRQ_TWDOG_INTID for the Tegra210, Tegra186 and Tegra194 platforms to fix the compilation failures.
Version 2.6
New features
    • Firmware Framework for Arm A-profile(FF-A)
    • Realm Management Extensions(RME)
    • Embedded Trace Extension and Trace Buffer Extension (ETE and TRBE)
TFTF
  • FF-A testing:
    • Update FF-A version to v1.1
    • Added helpers for SPM tests to check partition info of SPs from normal world.
    • Added tests to check for ffa_features supported.
    • Added test for FFA_RXTX_UNMAP ABI.
    • Added test for FFA_SPM_ID_GET.
    • FF-A v1.1 Notifications
      • Added test for notifications bitmap create and destroy ABIs.
      • Added test for notifications set and get ABIs.
      • Added test for notification INFO_GET ABI.
      • Added test to check notifications pending interrupt is injected into and handled by the expected vCPU in a MP setup.
      • Added test for signaling from MP SP to UP SP.
      • Added test to check notifications interrupt IDs retrieved with FFA_FEATURES ABI.
      • Added test to check functionality of notifications scheduled receiver interrupt.
      • Added support for handling secure interrupts in Cactus SP.
      • Added several tests to exercise secure interrupt handling while SP is in WAITING/RUNNING/BLOCKED state.
  • New tests:
    • Enabled SVE tests
    • Added test for trace system registers access.
    • Added test for trace filter control registers access.
    • Added test for trace buffer control registers access.
    • Added test to check PSTATE in SDEI handler.
    • Added test to check if HCRX_EL2 is accessible.
  • Platforms:
    • TC0:
      • Support for direct messaging with managed exit.
      • Support for building S-EL0 Ivy partition.
    • FVP:
      • Update Cactus secure partitions to indicate Managed exit support.
  • Miscellaneous
    • Added random seed generation capability and ability to specify build parameters for SMC Fuzzer tool.
  • Added helper for Cactus SP sleep.
  • Added test commands to request use of notifications interfaces.
  • Added several commands that generate direct message requests to assist in testing secure interrupt handling and notifications features in FF-A v1.1
  • Added support for SP805 Trusted Watchdog module.
Ivy (Secure-EL1 test partition)
  • Add shim layer to Ivy partition and enable PIE.
  • Define Ivy partition manifest and use FF-A for message handling.
  • Prepare S-EL1/0 enviroment for enabling S-EL0 application.
Realm Management Extension(RME)
  • Added tests to run RMI and SPM on multiple CPUs concurrently.
  • Added tests for multi CPU delegation and fail conditions.
  • Added tests to query RMI version on multiple CPUs.
  • Fixed Ivy partition start address for TC0.
  • Fixed SP manifests to use little endian format UUID.
  • Fixed a bug in memory sharing test for Cactus SP.
  • Invalidate data cache for NS_BL1U and NS_BL2U images.
  • Fixed attributes to Read-Write only for memory regions described in partition manifests.
Version 2.5
New features
    • True Random Number Generator (TRNG) test scenarios.
    • Multicore / Power State Controller Interface (PSCI) tests.
    • v8.6 Activity Monitors Unit (AMU) enhancements test scenarios.
    • Secure Partition Manager (SPM) / Firmware Framework (FF-A) v1.0 testing.
      • Interrupt Handling between Non-secure and Secure world.
      • Direct messages and memory sharing between Secure Partitions(SP).
      • Many tests to exercise FF-A v1.0 ABIs.
      • SPM saving/restoring the NS SIMD context enabling a normal world FF-A endpoint (TFTF) and a secure partition to use SIMD vectors and instructions independently.
TFTF
  • SPM / FF-A v1.0 testing.
    • Refactor FF-A memory sharing tests
      • Created helper functions to initialize ffa_memory_region and to send the respective memory region to the SP, making it possible to reuse the logic in SP-to-SP memory share tests.
      • Added comments to document relevant aspects about memory sharing.
    • Trigger direct messaging between SPs.
      • Use cactus command ‘CACTUS_REQ_ECHO_SEND_CMD’ to make cactus SPs communicate with each other using direct message interfaces.
    • Added helpers for SPM tests.
      • Checking SPMC has expected FFA_VERSION.
      • Checking that expected FF-A endpoints are deployed in the system.
      • Getting global TFTF mailbox.
  • Replace ‘.inst’ AArch64 machine directives with CPU Memory Tagging Extension instructions in ‘test_mte_instructions’ function.
  • Add build option for Arm Feature Modifiers.
    • This patch adds a new ARM_ARCH_FEATURE build option to add support for compiler’s feature modifiers.
  • Enable 8 cores support for Theodul DSU(DynamIQ Shared Unit) for the Total Compute (TC0) platform.
  • New tests:
    • Remove redundant code and add better tests for TRNG SMCs.
      • Tests that the Version, Features, and RND calls conform to the spec.
    • New tests for v8.6 AMU enhancements (FEAT_AMUv1p1)
      • Make sure AMU offsets are being saved and restored properly.
    • Tests to request SP-to-SP memory share.
    • SP-to-SP direct messaging deadlock test.
      • TFTF sends CACTUS_REQ_DEADLOCK_CMD to cactus SP.
Cactus(Secure-EL1 test partition)
  • Enable managed exit for primary cactus secure partition.
  • Helper commands needed for interrupt testing.
  • Add handler from managed exit FIQ interrupt.
  • Make ffa_id global.
  • Implement HF_INTERRUPT_ENABLE Hafnium hypervisor call wrapper. With this service, a secure partition calls into the SPMC to enable/disable a particular virtual interrupt.
  • Invalidate the data cache for the cactus image.
    • CACTUS_SLEEP_CMD & CACTUS_INTERRUPT_CMD added.
  • Decouple exception handling from tftf framework.
    • With new interrupt related tests coming up in Cactus, added separate exception handler code for irq/fiq in Cactus.
  • Hypervisor calls moved to a separate module.
  • Add secondary entry point register function.
  • Declare third SP instance as UP SP.
  • Provision a cold boot path for secondary cores (or secondary pinned execution contexts).
  • Tidy message loop, commands definitions, direct messaging API definitions.
  • Helpers for error logging after FF-A calls.
  • Properly placing Cactus test files.
  • Tidying FF-A Memory Sharing tests.
  • Use CACTUS_ECHO_CMD in direct message tests.
  • Refactor handling of commands.
    • Added helper macros to define a command handler, build a command table in which each element is a pair of the handler and respective command ID. Available tests have been moved to their own command handler.
  • Extend arguments in commands responses.
    • In the test commands framework, added template to extend number of values to include in a command response.
  • Check FF-A return is a valid direct response.
    • Added a helper function to check if return of FFA_MSG_SEND_DIRECT_REQ is FFA_MSG_SEND_DIRECT_RESP.
  • FFA_MSG_DIRECT_RESP call extended to use 5 registers.
  • Added accessors for arguments from FF-A calls.
    • Some accessors for arguments from FF-A calls, namely for func id, error code, and direct message destination/source.
  • Use virtual counter for sp_sleep.
    • Changes sp_sleep() to use virtual counter instead of physical counter.
  • Checks if SIMD vectors are preserved in the normal world while transitioning from normal world to secure world and back to normal world.
  • Tidying common code to tftf and cactus.
  • Refactor cactus_test_cmds.h to incorporate static inline functions instead of macros to enforce type checking.
  • Removed reference to Hafnium in name from helper function and macro to make them generic.
  • For consistency added the cmd id ‘CACTUS_MEM_SEND_CMD’.
  • Add command to request memory sharing between SPs.
  • Add & handle commands ‘CACTUS_REQ_ECHO_CMD’ and ‘CACTUS_ECHO_CMD’.
  • Update README with list of sample partitions.
  • Remove reference to PSA from xml test file.
  • Reduce tests verbosity in release mode.
    • Update few NOTICE messages to VERBOSE/INFO.
  • Fix conversion issues on cactus responses.
  • Create RXTX map/configure helper macros and use them.
  • Update OP-TEE version used for testing to 3.10.
    • SPMC as S-EL1 tests using OP-TEE depend on a static binary stored as a CI file. This binary corresponds to a build of OP-TEE v3.10.
  • Add uart2 to device-regions node.
    • First SP no longer has an open access to the full system peripheral range and devices must be explicitly declared in the SP manifest.
  • New tests:
    • Test for exercising SMMUv3 driver to perform stage2 translation.
    • Test handling of non-secure interrupt while running SP.
    • Add secondary cores direct messaging test for SPM.
    • Testing deadlock by FF-A direct message.
      • Added command CACTUS_DEADLOCK_CMD to file cactus_test_cmds.h to create a deadlock scenario using FF-A direct message interfaces.
    • Test SP-to-SP memory share operations
      • Handle ‘CACTUS_REQ_MEM_SEND_CMD’ by sending memory to the receiver SP.
    • Implemented test to validate FFA_RXTX_MAP ABI.
Version 2.4
New features
  • More tests are made available in this release to help validate the functionalities in the following areas: - SMCCC. - New architecture specific features. - FF-A features. - New platform ports.
  • Various improvements to test framework and test suite such as documentation, removing un-necessary dependencies, etc.
TFTF
  • Remove dependencies from FVP to generic code by converting some FVP platform specific macros to the common macros.
  • Remove make as a package dependency to compile TF-A test code.
  • Move defaults values and macro defs in a separate folder from Makefile.
  • Allow alternate stdout to be used apart from pl011 UART.
  • Get FVP platform’s topology from build options to make FVP platform configuration more flexible and eliminate test errors when the platform is configured with number of CPUs less than default values in the makefile.
  • Update the FIP corrupt address which is used to corrupt BL2 image that helps to trigger firmware update process.
  • Add explicit barrier before sev() in tftf_send_event_common API to avoid core hang.
  • Align output properly on issuing make help_tests by removing dashes and sort tests.
  • Moved a few FVP and Juno specific defined from common header files to platform specific header files.
  • Replace SPCI with PSA FF-A in code as SPCI is now called as FF-A.
  • Add owner field to sp_layout generation to differentiate owner of SP which could either be Silicon Provider or Platform provider.
  • Add v8.5 Branch Target Identifier(BTI) support in TFTF.
  • Remove dependency on SYS_CNT_BASE1 to read the memory mapped timers.
  • Enables SError aborts for all CPUs, during their power on sequence.
  • Documentation:
    • Use conditional assignment on sphinx variables so that they can be overwritten by environment and/or command line.
    • Add support for documentation build as a target in Makefile.
    • Update list of maintainers.
    • Update documentation to explain how to locally build the documentation.
    • Add .editorconfig from TF-A to define the coding style.
    • Fix documentation to include ‘path/to’ prefix when specifying tftf.bin on make fip cmd.
    • Use docker to build documentation.
    • Replace SPCI with PSA FF-A in documentation as SPCI is now called as FF-A.
  • NVIDIA Tegra194:
    • Skip CPU suspend tests requiring SGI as wake source as Tegra194 platforms do not support CPU suspend power down and cannot be woken up with an SGI.
    • Disable some system suspend test cases.
    • Create dummy SMMU context for system resume to allow the System Resume Firmware to complete without any errors or warnings.
    • Increase RTC step value to 5ms as RTC consumes 250us for each register read/write. Increase the step value to 5ms to cover all the register read/write in program_timer().
    • Skip some timer framework validation tests as CPUs on Tegra194 platforms cannot be woken up with the RTC timer interrupt after power off.
    • Introduce per-CPU Hypervisor Timer Interrupt ID.
    • Skip PSCI STAT tests requiring PSTATE_TYPE_POWERDOWN as Tegra194 platforms do not support CPU suspend with state type as PSTATE_TYPE_POWERDOWN.
    • Disable boot requirement tests as Tegra194 platforms do not support memory mapped timers.
    • Skips the test “Create all power states and validate EL3 power state parsing” from the “EL3 power state parser validation” test suite as it is not in sync with this expectation.
    • Moved reset, timers. wake, watchdog drivers from Tegra194 specific folder to common driver folder so that these drivers can be used for other NVIDIA platforms.
  • New tests:
    • Add test for SDEI RM_ANY routing mode.
    • Add initial platform support for TC0.
    • Add SMC fuzzing module test.
    • Add test case for SMCCC_ARCH_SOC_ID feature.
    • Add test that supports ARMv8.6-FGT in TF-A.
    • Add test that supports ARMv8.6-ECV in TF-A.
    • Add test for FFA_VERSION interface.
    • Add test for FFA_FEATURES interface.
    • Add console driver for the TI UART 16550.
    • Add tests for FF-A memory sharing interfaces between tftf and cactus secure partitions.
    • NVIDIA Tegra194:
      • Introduce platform port for Tegra194 to to initialize the tftf framework and execute tests on the CPUs.
      • Introduce power management support.
      • Introduce support for RTC as wake source.
      • Introduce system reset functionality test.
      • Introduce watchdog timer test.
      • Introduce support for NVIDIA Denver CPUs.
      • Introduce RAS uncorrectable error injection test.
      • Introduce tests to verify the Video Memory resize interface.
      • Introduce test to inject RAS corrected errors for all supported nodes from all CPUs.
      • Introduce a test to get return value from SMC SiP function TEGRA_SIP_GET_SMMU_PER.
    • NVIDIA Tegra196:
      • Introduce initial support for Tegra186 platforms.
    • NVIDIA Tegra210:
      • Introduce initial support for Tegra210 platforms.
Secure partition - Cactus
  • TFTF doesn’t need to boot Secondary Cactus as Hafnium now boots all partitions according to “boot-order” field value in the partition manifests.
  • Remove test files related to deprecated SPCI Alpha specification and SPRT interface.
  • Select different stdout device at runtime as primary VM can access to UART while secondary VM’s use hypervisor call to SPM for debug logging.
  • An SP maps its RX/TX buffers in its EL1&0 Stage-1 translation regime. The same RX/TX buffers are mapped by the SPMC in the SP’s EL1&0 Stage-2 translation regime during boot time.
  • Update memory/device region nodes in manifest. Memory region has 3 entries such as RX buffer, TX buffer and dummy. These memory region entries are mapped with attributes as “RX buffer: read-only”, “TX buffer: read-write” and “dummy: read-write-execute”. Device region mapped with read-write attribute.
  • Create tertiary partition without RX_TX region specified to test the RXTX_MAP API.
  • Add third partition to ffa_partition_info_get test to test that a partition can successfully get information about the third cactus partition.
  • Map RXTX region to third partition to point the mailbox to this RXTX region.
  • Adjust the number of EC context to max number of PEs as per the FF-A specification mandating that a SP must either “Implement as many ECs as the number of PEs (in case of a “multi-processor” SP with pinned contexts)” or “Implement a single EC (in case of a migratable “uni-processor” SP).
  • Updated cactus test payload and TFTF ids as it is decided to have secure partition FF-A ids in the range from 0x8001 to 0xfffe, 0x8000 and 0xffff FF-A ids are reserved for the SPMC and the SPMD respectively and in the non-secure worlds, FF-A id 0 is reserved for the hypervisor and 1 to 0x7fff FF-A ids are reserved for VMs.
  • Break the message loop on bad message request instead of replying with the FF-A error ABI to the SPMC.
  • Remove deprecated hypervisor calls spm_vm_get_count and spm_vcpu_get_count. Instead use FFA_PARTITION_INFO_GET discovery ABI.
  • Implement hvc call ‘SPM_INTERRUPT_GET’ to get interrupt id.
  • Re-structure platform dependent files by moving platform dependent files and macros to platform specific folder.
  • Adjust partition info get properties to support receipt of direct message request.
  • New tests:
    • Add FFA Version Test.
    • Add FFA_FEATURES test.
    • Add FFA_MEM_SHARE test
    • Add FFA_MEM_LEND test.
    • Add FFA_MEM_DONATE test.
    • Add FFA_PARTITION_INFO_GET test.
    • Add exception/interrupt framework.
    • Add cactus support for TC0 platform.
  • Update link to SMCCC specification.
  • Trim down the top-level readme file to give brief overview of the project and also fix/update a number of broken/out-dated links in it.
  • Bug fix in Multicore IRQ spurious test.
  • Fix memory regions mapping with no NS bit set.
  • Reenable PSCI NODE_HW_STATE test which was disabled earlier due to outdated SCP firmware.
  • Fix Aarch32 zeromem() function by avoiding infinite loop in ‘zeromem’ function and optimizing ‘memcpy4’ function.
  • Add missing help_tests info on help target in the top-level Makefile.
  • Trim down the readme file as it does not need to provide detailed information, instead it can simply be a landing page providing a brief overview of the project and redirecting the reader to RTD for further information.
  • Fix maximum number of CPUs in DSU cluster by setting maximum number of CPUs in DSU cluster to 8.
Version 2.3
New features
  • More tests are made available in this release to help validate the functionality of TF-A.
  • CI upgraded to use GCC 9.2-2019.12 toolchain for tf-a-tests.
  • Various improvements to test framework and test suite.
TFTF
  • Support for extended register usage as per SMCCC v1.2 specification.
  • Support for FVP platforms with SMT capabilities.
  • Improved support for documentation through addition of basic Sphinx configuration and Makefile similar to TF-A repository.
  • Enhancement to libc library synchronous to TF-A code base.
  • ARMv8.3-PAuth enabled for all FWU tests in TFTF.
  • TFTF made RFC 4122 compliant by converting UUIDs to network order format.
  • Build improvement by deprecating custom AARCH64/AARCH32 macros in favor of __arch64__ macro provided by compiler.
  • Support for HVC as a SMCCC conduit in TFTF.
  • New tests:
    • AArch32 tests for checking if PMU counters leak in secure world.
    • Add new debug filesystem (debugfs) test.
    • Add a SPCI direct messaging test targeting bare-metal cactus SP.
Secure partitions
Cactus
  • Several build improvements and symbol relocation fixup to make it position independent executable.
  • Update of sample manifest to SPCI Beta1 format.
  • Support for generating JSON file as required by TF-A.
  • Makefile bug fix for performing parallel builds.
  • Add missing D-cache invalidation of RW memory in tftf_entrypoint to safeguard against possible corruption.
  • Fixes in GIC drivers to support base addresses beyond 4G range.
  • Fix build with XML::LibXML 2.0202 Perl module
Known issues and limitations
The sections below list the known issues and limitations of each test image provided in this repository. Unless and otherwise stated, issues and limitations stated in previous release continue to exist in this release.
TFTF
  • NODE_HW_STATE test has been temporarily disabled for sgi575 platform due to a dependency on SCP binaries version 2.5
Version 2.2
New features
  • A wide range of tests are made available in this release to help validate the functionality of TF-A.
TFTF
  • Enhancement to xlat table library synchronous to TF-A code base.
  • Enabled strict alignment checks (SCTLR.A & SCTLR.SA) in all images.
  • Support for a simple console driver. Currently it serves as a placeholder with empty functions.
  • A topology helper API is added in the framework to get parent node info.
  • Support for FVP with clusters having upto 8 CPUs.
  • Enhanced linker script to separate code and RO data sections.
  • Relax SMC calls tests. The SMCCC specification recommends Trusted OSes to mitigate the risk of leaking information by either preserving the register state over the call, or returning a constant value, such as zero, in each register. Tests only allowed the former behaviour and have been extended to allow the latter as well.
  • Pointer Authentication enabled on warm boot path with individual APIAKey generation for each CPU.
  • New tests:
    • Basic unit tests for xlat table library v2.
    • Tests for validating SVE support in TF-A.
    • Stress tests for dynamic xlat table library.
    • PSCI test to measure latencies when turning ON a cluster.
    • Series of AArch64 tests that stress the secure world to leak sensitive counter values.
    • Test to validate PSCI SYSTEM_RESET call.
    • Basic tests to validate Memory Tagging Extensions are being enabled and ensuring no undesired leak of sensitive data occurs.
  • Enhanced tests:
    • Improved tests for Pointer Authentication support. Checks are performed to see if pointer authentication keys are accessible as well as validate if secure keys are being leaked after a PSCI version call or TSP call.
    • Improved AMU test to remove unexecuted code iterating over Group1 counters and fix the conditional check of AMU Group0 counter value.
Secure partitions
A new Secure Partition Quark is introduced in this release.
Quark
The Quark test secure partition provided is a simple service which returns a magic number. Further, a simple test is added to test if Quark is functional.
  • Bug fix in libc memchr implementation.
  • Bug fix in calculation of number of CPUs.
  • Streamlined SMC WORKAROUND_2 test and fixed a false fail on Cortex-A76 CPU.
  • Pointer Authentication support is now available for secondary CPUs and the corresponding tests are stable in this release.
TFTF
  • Multicore spurious interrupt test is observed to have unstable behavior. As a temporary solution, this test is skipped for AArch64 Juno configurations.
  • Generating SVE instructions requires O3 compilation optimization. Since the current build structure does not allow compilation flag modification for specific files, the function which tests support for SVE has been pre-compiled and added as an assembly file.
Version 2.1
New features
  • Add initial support for testing Secure Partition Client Interface (SPCI) and Secure Partition Run-Time (SPRT) standards.
    Exercise the full communication flow throughout the software stack, involving:
    • A Secure-EL0 test partition as the Trusted World agent.
    • TFTF as the Normal World agent.
    • The Secure Partition Manager (SPM) in TF-A.
  • Various stability improvements, code refactoring and clean ups.
TFTF
  • Reorganize tests build infrastructure to allow the selection of a subset of tests.
  • Reorganize the platform layer for improved clarity and simplicity.
  • Sanitise inclusion of drivers header files.
  • Enhance the test report format for improved clarity and conciseness.
  • Dump CPU registers when hitting an unexpected exception. Previously, this would silently loop forever.
  • Import libc from TF-A to better align the two code bases.
  • New tests:
    • SPM tests for exercising communication through either the MM or SPCI/SPRT interfaces.
    • SMC calling convention tests.
    • Initial tests for Armv8.3 Pointer Authentication support (experimental).
  • New platform ports:
Secure partitions
We now have 3 Secure Partitions to test the SPM implementation in TF-A.
Cactus-MM
The Cactus test secure partition provided in version 2.0 has been renamed into “Cactus-MM”. It is still responsible for testing the SPM implementation based on the Arm Management Mode Interface.
Cactus
This is a new test secure partition (as the former “Cactus” has been renamed into “Cactus-MM”, see above).
Unlike Cactus-MM, this image tests the SPM implementation based on the SPCI and SPRT draft specifications.
It runs in Secure-EL0 and performs the following tasks:
  • Test that TF-A has correctly setup the secure partition environment (access to cache maintenance operations, to floating point registers, etc.)
  • Test that TF-A accepts to change data access permissions and instruction permissions on behalf of Cactus for memory regions the latter owns.
  • Test communication with SPM through SPCI/SPRT interfaces.
Ivy
This is also a new test secure partition. It is provided in order to test multiple partitions support in TF-A. It is derived from Cactus and essentially provides the same services but with different identifiers at the moment.
EL3 payload
  • The GICv2 spurious IRQ test is no longer Juno-specific. It is now only GICv2-specific.
  • The manual tests in AArch32 state now work properly. After investigation, we identified that this issue was not AArch32 specific but concerned any test relying on state information persisting across reboots. It was due to an incorrect build configuration.
  • Cactus-MM now successfully links with GNU toolchain 7.3.1.
The sections below lists the known issues and limitations of each test image provided in this repository.
TFTF
The TFTF test image might be conceptually sub-divided further in 2 parts: the tests themselves, and the test framework they are based upon.
Test framework
  • Some stability issues.
  • No mechanism to abort tests when they time out (e.g. this could be implemented using a watchdog).
  • No convenient way to include or exclude tests on a per-platform basis.
  • Power domains and affinity levels are considered equivalent but they may not necessarily be.
  • Need to provide better support to alleviate duplication of test code. There are some recurrent test patterns for which helper functions should be provided. For example, bringing up all CPUs on the platform and executing the same function on all of them, or programming an interrupt and waiting for it to trigger.
  • Every CPU that participates in a test must return from the test function. If it does not - e.g. because it powered itself off for testing purposes - then the test framework will wait forever for this CPU. This limitation is too restrictive for some tests.
  • No protection against interrupted flash operations. If the target is reset while some data is written to flash, the test framework might behave incorrectly on reset.
  • When compiling the code, if the generation of the tests_list.c and/or tests_list.h files fails, the build process is not aborted immediately and will only fail later on.
  • The directory layout requires further improvements. Most of the test framework code has been moved under the tftf/ directory to better isolate it but this effort is not complete. As a result, there are still some TFTF files scattered around.
  • Pointer Authentication testing is experimental and incomplete at this stage. It is only enabled on the primary CPU on the cold boot.
Tests
  • Some tests are implemented for AArch64 only and are skipped on AArch32.
  • Some tests are not robust enough:
    • Some tests might hang in some circumstances. For example, they might wait forever for a condition to become true.
    • Some tests rely on arbitrary time delays instead of proper synchronization when executing order-sensitive steps.
    • Some tests have been implemented in a practical manner: they seem to work on actual hardware but they make assumptions that are not guaranteed by the Arm architecture. Therefore, they might fail on some other platforms.
  • PSCI stress tests are very unreliable and will often hang. The root cause is not known for sure but this might be due to bad synchronization between CPUs.
  • The GICv2 spurious IRQ test sometimes fails with the following error message:
    SMC @ lead CPU returned 0xFFFFFFFF 0x8 0xC
    The root cause is unknown.
  • The FWU tests take a long time to complete. This is because they wait for the watchdog to reset the system. On FVP, TF-A configures the watchdog period to about 4 min. This limit is excessive for an automated testing context and leaves the user without feedback and unable to determine if the tests are proceeding properly.
  • The test “Target timer to a power down cpu” sometimes fails with the following error message:
    Expected timer switch: 4 Actual: 3
FWU images
  • The FWU tests do not work on the revC of the Base AEM FVP. They only work on the revB.
  • NS-BL1U and NS-BL2U images reuse TFTF-specific code for legacy reasons. This is not a clean design and may cause confusion.
Test secure partitions (Cactus, Cactus-MM, Ivy)
  • This is experimental code. It’s likely to change a lot as the secure partition software architecture evolves.
  • Supported on AArch64 FVP platform only.
All test images
  • TF-A Tests are derived from a fork of TF-A so:
    • they’ve got some code in common but lag behind on some features.
    • there might still be some irrelevant references to TF-A.
  • Some design issues. E.g. TF-A Tests inherited from the I/O layer of TF-A, which still needs a major rework.
  • Cannot build TF-A Tests with Clang. Only GCC is supported.
  • The build system does not cope well with parallel building. The user should not attempt to run multiple jobs in parallel with the -j option of GNU make.
  • The build system does not properly track build options. A clean build must be performed every time a build option changes.
  • UUIDs are not compliant to RFC 4122.
  • No floating point support. The code is compiled with GCC flag -mgeneral-regs-only, which prevents the compiler from generating code that accesses floating point registers. This might limit some test scenarios.
  • The documentation is too lightweight.
  • Missing instruction barriers in some places before reading the system counter value. As a result, the CPU could speculatively read it and any delay loop calculations might be off (because based on stale values). We need to examine all such direct reads of the CNTPCT_EL0 register and replace them with a call to syscounter_read() where appropriate.
Version 2.0
New features
This is the first public release of the Trusted Firmware-A Tests source code.
TFTF
  • Provides a baremetal test framework to exercise TF-A features through its SMC interface.
  • Integrates easily with TF-A: the TFTF binary is packaged in the FIP image as a BL33 component.
  • Standalone binary that runs on the target without human intervention (except for some specific tests that require a manual target reset).
  • Designed for multi-core testing. The various sub-frameworks allow maximum parallelism in order to stress the firmware.
  • Displays test results on the UART output. This may then be parsed by an external tool and integrated in a continuous integration system.
  • Supports running in AArch64 (NS-EL2 or NS-EL1) and AArch32 states.
  • Supports parsing a tests manifest (XML file) listing the tests to include in the binary.
  • Detects most platform features at run time (e.g. topology, GIC version, …).
  • Provides a topology enumeration framework. Allows tests to easily go through affinity levels and power domain nodes.
  • Provides an event framework to synchronize CPU operations in a multi-core context.
  • Provides a timer framework. Relies on a single global timer to generate interrupts for all CPUs in the system. This allows tests to easily program interrupts on demand to use as a wake-up event source to come out of CPU suspend state for example.
  • Provides a power-state enumeration framework. Abstracts the valid power states supported on the platform.
  • Provides helper functions for power management operations (CPU hotplug, CPU suspend, system suspend, …) with proper saving of the hardware state.
  • Supports rebooting the platform at the end of each test for greater independence between tests.
  • Supports interrupting and resuming a test session. This relies on storing test results in non-volatile memory (e.g. flash).
FWU images
  • Provides example code to exercise the Firmware Update feature of TF-A.
  • Tests the robustness of the FWU state machine implemented in the TF-A by sending valid and invalid authentication, copy and image execution requests to the TF-A BL1 image.
EL3 test payload
  • Tests the ability of TF-A to load an EL3 payload.
  • Tests that TF-A has correctly setup the secure partition environment: it should be allowed to perform cache maintenance operations, access floating point registers, etc.
  • Tests the ability of a secure partition to request changing data access permissions and instruction permissions of memory regions it owns.
  • Tests the ability of a secure partition to handle StandaloneMM requests.
TFTF
Test framework
  • The directory layout is confusing. Most of the test framework code has been moved under the tftf/ directory to better isolate it but this effort is not complete. As a result, there are still some TFTF files scattered around.
Tests
  • The GICv2 spurious IRQ test is Juno-specific. In reality, it should only be GICv2-specific. It should be reworked to remove any platform-specific assumption.
  • The manual tests in AArch32 mode do not work properly. They save some state information into non-volatile memory in order to detect the reset reason but this state does not appear to be retained. As a result, these tests keep resetting infinitely.
  • The FWU tests take a long time to complete. This is because they wait for the watchdog to reset the system. On FVP, TF-A configures the watchdog period to about 4 min. This is way too long in an automated testing context. Besides, the user gets not feedback, which may let them think that the tests are not working properly.
FWU images
  • Cactus is experimental code. It’s likely to change a lot as the secure partition software architecture evolves.
  • Fails to link with GNU toolchain 7.3.1.
  • Cactus is supported on AArch64 FVP platform only.
All test images
  • SMCCC v2 is not properly supported.
Copyright (c) 2018-2025, Arm Limited. All rights reserved.
