Build Options Summary
As far as possible, TF-A Tests dynamically detects the platform hardware components and available features. There are a few build options to select specific features where the dynamic detection falls short.
Unless mentioned otherwise, these options are expected to be specified at the build command line and are not to be modified in any component makefiles.
The build system doesn’t track dependencies for build options. Therefore, if any of the build options are changed from a previous build, a clean build must be performed.
Arm FVP Platform Specific Build Options
FVP_CLUSTER_COUNT: Configures the cluster count to be used to build the topology tree within TFTF. By default TFTF is configured for dual cluster for CPUs with single thread (ST) and single cluster for SMT CPUs. For ST CPUs this option can be used to override the default number of clusters with a value in the range 1-4.FVP_MAX_CPUS_PER_CLUSTER: Sets the maximum number of CPUs implemented in a single cluster. This option defaults to the maximum value of 4 for ST CPUs and maximum value of 8 for SMT CPUs.FVP_MAX_PE_PER_CPU: Sets the maximum number of PEs implemented on any CPU in the system. This option defaults to 1 to select ST CPUs. For platforms with SMT CPUs this value must be set to 2.
TFTF-specific Build Options
NEW_TEST_SESSION: Choose whether a new test session should be started every time or whether the framework should determine whether a previous session was interrupted and resume it. It can take either 1 (always start new session) or 0 (resume session as appropriate). 1 is the default.TESTS: Set of tests to run. Use the following command to list all possible sets of tests:make help_tests
If no set of tests is specified, the standard tests will be selected (see
tftf/tests/tests-standard.xml).USE_NVM: Used to select the location of test results. It can take either 0 (RAM) or 1 (non-volatile memory like flash) as test results storage. Default value is 0, as writing to the flash significantly slows tests down.
Cactus SP Build Options
SPMC_AT_EL3: This flag is required to match the feature set of Cactus SP thatare implemented in TF-A EL3 SPMC. Default value is 0.
CACTUS_PWR_MGMT_SUPPORT: If a Cactus SP subscribes to receiving power management framework message through its partition manifest, this flag controls whether the SP supports handling the aforementioned message. This option can take either 0 (unsupported) or 1 (supported). Default value is 1.Note that a value of 0 is particularly useful in stress testing of power management handling by the SPMC.
Realm payload specific Build Options
ENABLE_REALM_PAYLOAD_TESTS=1This option builds and packs Realm payload tests realm.bin to tftf.bin.
FWU-specific Build Options
FIRMWARE_UPDATE: Whether the Firmware Update test images (i.e.NS_BL1UandNS_BL2U) should be built. The default value is 0. The platform makefile is free to override this value if Firmware Update is supported on this platform.
Copyright (c) 2019-2020, Arm Limited. All rights reserved.
