Implementing Tests
This document aims at providing some pointers to help implementing new tests in the TFTF image.
Test Structure
A test might be divided into 3 logical parts, detailed in the following sections.
Prologue
A test has a main entry point function, whose type is:
typedef test_result_t (*test_function_t)(void);
See tftf/framework/include/tftf.h.
Only the primary CPU enters this function, while other CPUs are powered down.
First of all, the test function should check whether this test is applicable to
this platform and environment. Some tests rely on specific hardware features or
firmware capabilities to be present. If these are not available, the test should
be skipped. For example, a multi-core test requires at least 2 CPUs to
run. Macros and functions are provided in include/common/test_helpers.h to
help test code verify that their requirements are met.
Core
This is completely dependent on the purpose of the test. The paragraphs below just provide some useful, general information.
The primary CPU may power on other CPUs by calling the function
tftf_cpu_on(). It provides an address to which secondary CPUs should jump
to once they have been initialized by the test framework. This address should be
different from the primary CPU test function.
Synchronization primitives are provided in include/lib/events.h in case CPUs’
execution threads need to be synchronized. Most multi-processing tests will need
some synchronisation points that all/some CPUs need to reach before test
execution may continue.
Any CPU that is involved in a test must return from its test function. Failure to do so will put the framework in an unrecoverable state, see the Change Log & Release Notes for details on this and other known limitations. The return code indicates the test result from the point of view of this CPU. At the end of the test, individual CPU results are aggregated and the overall test result is derived from that. A test is considered as passed if all involved CPUs reported a success status code.
Epilogue
Each test is responsible for releasing any allocated resources and putting the system back in a clean state when it finishes. Any change to the system configuration (e.g. MMU setup, GIC configuration, system registers, …) must be undone and the original configuration must be restored. This guarantees that the next test is not affected by the actions of the previous one.
One exception to this rule is that CPUs powered on as part of a test must not be powered down. As already stated above, as soon as a CPU enters the test, the framework expects it to return from the test.
Template Test Code
Some template test code is provided in tftf/tests/template_tests. It can be
used as a starting point for developing new tests. Template code for both
single-core and multi-core tests is provided.
Build System Integration
All test code is located under the tftf/tests directory. Tests are usually
divided into categories represented as sub-directories under tftf/tests/.
The source file implementing the new test code should be added to the
appropriate tests makefile, see .*mk files under tftf/tests.
The new test code should also appear in a tests manifest, see *.xml files
under tftf/tests. A unique name and test function must be provided. An
optional description may be provided as well.
For example, to create a test case named “Foo test case”, whose test
function is foo(), add the following line in the tests manifest:
<testcase name="Foo test case" function="foo" />
A testcase must be part of a testsuite. The testcase XML node above must be
inside a testsuite XML node. A unique name and a description must be
provided for the testsuite.
For example, to create a test suite named “Bar test suite”, whose
description is: “An example test suite”, add the following 2 lines:
<testsuite name="Bar test suite" description="An example test suite">
</testsuite>
See the template test manifest for reference: tftf/tests/tests-template.xml.
Copyright (c) 2018-2020, Arm Limited. All rights reserved.
