Realm Test Lifecycle
RME-enabled tests share basic host setup before exercising the Realm Management Monitor (RMM). Testcase setup and cleanup hooks put this common lifecycle around the test body, so each test can concentrate on its resources and assertions. Build and packaging instructions are in Building TF-A Tests, which also links to the TF-A RME guide.
Framework hooks
The RME lifecycle uses the generic Testcase Lifecycle Hooks capability. See Registering Testcase Hooks for callback registration, suite and testcase filters, and source build integration. The framework runs these callbacks on the lead CPU; tests synchronise secondary CPUs and release their RMM objects before returning.
RME hook selection
The shared RME hooks are registered by host_realm_helper.c for the
Realm/RMM-dependent suites: Realm payload at EL1, RMI and SPM
tests, SP exceptions, and Invalid memory access with RME
extension. Within SMMUv3 tests, they are registered only for
Check secure peripheral access to a realm region is aborted.
Thus, RME-enabled tests selected by these registrations receive the
common lifecycle. Enabling Realm payload support does not apply RMM
setup to every test in a broad build such as TESTS=standard or
TESTS=spm. RMM-dependent suites or testcases should register both
hooks with the appropriate scope.
Basic setup and RMM activation
host_realm_testcase_setup() establishes the default environment:
Check RME support, reset the RMI register-comparison result, and probe RMI version. Tests retain their own feature and skip checks.
Retry any previous pool cleanup and deactivate the previous RMM lifecycle. Stop if it still owns resources; do not change tracking size or reset its allocation cursor.
Initialise the host Realm heap used for test allocations and memory donated to the RMM.
Select the tracking size, configure the RMM with 4 KB granules, and activate it. The common setup selects either 1 GB or 2 MB tracking regions for each testcase.
Begin the testcase pool lifecycle so tracking metadata can be reclaimed at cleanup.
If RME or the RMI interface is unavailable, setup leaves the testcase to
perform its usual skip checks. The Test Realm Payload (TRP), which
reports RMI version zero, does not use the RMM activation path.
Both hooks reuse SKIP_TEST_IF_RME_NOT_SUPPORTED_OR_RMM_IS_TRP() through
an availability check. Its skip result makes the hooks return success
without RMM lifecycle operations, leaving each test’s own checks to
determine its skip or TRP result.
The RMM used with this lifecycle must implement RMI_RMM_STATE_GET,
RMI_RMM_CONFIG_GET, RMI_RMM_CONFIG_SET, RMI_RMM_ACTIVATE, and
RMI_RMM_DEACTIVATE, and support both tracking sizes with 4 KB granules.
Setup fails if the required lifecycle commands are unavailable.
The setup hook prepares the host environment; the test still creates
and destroys its own Realms, RECs, mappings, and device objects.
host_rmm_activate() checks the RMM state and returns successfully if
it is already active with the selected configuration. An active RMM with
a different configuration is rejected without changing the host helpers.
The common setup uses rand() to choose the layout before each testcase.
At LOG_LEVEL=40 or higher, it logs the testcase name, selected size,
and configuration request/result.
Cleanup and a test-controlled restart
host_realm_testcase_cleanup() reclaims testcase tracking metadata
and then deactivates the RMM only after reclamation succeeds. The known
Realm heap range is scanned
automatically. Fine tracking regions outside the heap, including regions
crossing its boundaries, are recorded explicitly and attempted first in
reverse completion order. Cleanup repeats passes over both sets while
regions are successfully restored from FINE tracking. This allows later
reclamations to release metadata that blocked earlier regions. Cleanup
stops when all regions are restored or a pass makes no progress; regions
already restored do not count as progress.
The heap is reset only after its tracking metadata has been reclaimed.
Reinitialising the pool during an active testcase preserves its allocation
cursor, including when another RMM object prevents cleanup after the last
Realm is destroyed. Failed testcase cleanup retains the registry and cursor
for a retry and blocks pool reinitialisation and a new pool lifecycle until
A test that does not need the default active RMM, or that needs a
different configuration, can perform the same cleanup sequence at the
start of its body and restart the lifecycle itself. The registered
callbacks are private to host_realm_helper.c; tests use their public
lifecycle helpers rather than calling the callbacks directly:
Synchronise participating CPUs and destroy any Realms or other RMM objects already created by the test.
Call
host_realm_pool_testcase_release()to reclaim tracking metadata, thenhost_rmm_deactivate()to return the RMM to its inactive state. Stop and report failure if either operation fails.Run the test’s inactive-state checks. To restart, initialise the heap with
host_realm_pool_init()and callhost_rmm_activate_with_tracking_size()with eitherRMI_GRAN_4KB_TRACKING_REGION_SIZE_1GBorRMI_GRAN_4KB_TRACKING_REGION_SIZE_2MB. This helper configures and activates the RMM and updates the host tracking helpers only on success. To reuse the last selected size, callhost_rmm_activate().After activation succeeds, call
host_realm_pool_testcase_begin()before creating objects or fine tracking regions for the new lifecycle. Check every return value and release the test’s objects before leaving its body.
For example, a test can restart with 2 MB tracking before creating its objects:
#include <host_realm_helper.h>
#include <host_realm_rmi.h>
#include <tftf.h>
test_result_t test_realm_with_2mb_tracking(void)
if (!host_realm_pool_testcase_release() || !host_rmm_deactivate()) {
return TEST_RESULT_FAIL;
if (!host_realm_pool_init() ||
!host_rmm_activate_with_tracking_size(
RMI_GRAN_4KB_TRACKING_REGION_SIZE_2MB) ||
!host_realm_pool_testcase_begin()) {
/* Create, exercise, and destroy the test's RMM objects here. */
return TEST_RESULT_SUCCESS;
Framework cleanup still runs when the test returns. Releasing an inactive testcase pool or deactivating an already inactive RMM succeeds, so an early cleanup does not suppress the final cleanup. A test that remains inactive need not restart the pool lifecycle.
Copyright (c) 2026, Arm Limited. All rights reserved.
